Question Would people recommend Trio monoblocks with mission 753 speakers
Jezza
9
Recently bought mission 753s on ebay for large room with the intention to listen to a range of music at loud volume. I understand that monoblock amps often feature in high end systems. Have te opportunity to buy a pair of kenwood trio L-07 monoblock power amplifuers, serviced and with 1 year warranty, for £750 (or less if I make an offer}
Would be used with a high quality dac and laptop input for now, pre amp and vinyl an option down the line.
Any thoughts on this combination?
Jezza
9
Monoblock speakers? Please clarify and is that seventeen or i7?
if you meant monoblock amplifiers then you are going to need a decent preamplifier in the system somewhere.
Thanks, edited to correct and clarify
Excellent. The L-07 monoblocks were hugely expensive when first released, if they have been well serviced and maintained then I wouldn't hesitate spending that sort of money on them but you're going to have to look at a similar amount to get a half -decent preamp to partner with them.
Reactions: Jezza
Jezza
9
Thanks Al ears. I have gone for the trio monoblocs and will have them next week.
You make a good point about the pre amp.
I've aquired a Rel B2 Britannia Sub as well. I'm looking to use a laptop for main input but also leave option open for vinyl and therefore need a dac/preamp that with the following features:
· Dual outputs
· Analogue input for turntable or other feed to act as full preamp with volume control
· USB input for laptop feed
Any recommendation, used, for around £750?
I've a quires a Rel B2 Britannia Sub as well. I'm looking to use a laptop for main input but also leave option open for vinyl and therefore need a dac/preamp that with the following features:
· Dual outputs
hopefully others will be along with suggestions, DAC / preamps are not my expertise.
insider9
1,060
538
6,070
If I understand what's required then Mytek Brooklyn DAC+ should match all the boxes. Some patience might be required to get it under £750 but a couple sold recently within the budget. As long as you're not pressed for time it's very doable.
Edit
Apologies, missed the sub. It's not that it's not doable. Mytek has both balanced and unbalanced out. If you utilise both one to go to mono blocks and the other to sub you're ok. Don't know what connections you have on your mono blocks or the sub.
Reactions: Jezza
ASK THE COMMUNITY
