WmA 9.2
GSB
282
Hi folks
Am after a bit of advice.
I have all my cd's ripped and converted to wma 9.2 and stored on a usb flash drive so they can be played in my car.
Now I have found just about every track skips,and not in the same place when played back!?
Could the problem be with the codec...is it worth the effort to batch convert all the albums to 320kbps?
Car unfortunately won't play flac.
GSB said:
Hi folks
Am after a bit of advice. I have all my cd's ripped and converted to wma 9.2 and stored on a usb flash drive so they can be played in my car.
Could the problem be with the codec...is it worth the effort to batch convert all the albums to 320kbps? Car unfortunately won't play flac. Thanks
I would like a car that plays Flac as well, I have used Mp3 fixed rate at 320kbps through my B&O system and is accetable for in car use.
Had WMAissues myself.
