- Aug 6, 2013
- 5
- 0
- 0
Hi folks,
I'm struggling to get a good handle on a question posing to myself.
If you spent £800+ on a set or separates (amp, speakers, wired/wireless DAC) or a all-in-one hi-res wireless speaker is it right to assume that the separates would, in theory, sound better?
I'm looking for as best quality system that can fit into my small lounge. In theory a all-in-on wireless speaker such as the Naim Mu-so would be a very neat solution but i'm ultimately thinking would that be the best way to spend £800+ in terms of quality.
You'll see that wireless integration is important, and a compact solution is even more pressing. I guess I need to know, if I purchased maybe something like bookshelf KEF's, a Arcam DAC and an acceptable amp, would this blow the Naim Mu-so (or similar) out of the water? If the answer is no, then a compact (quality) solution is for me.
Would a £500 buget flip the balance?
Priorities: 1) sound quality, 2) space, 3) budget
I'd be very keen to know your thoughts
Bob
Bob
