Andrewjvt said:
Can anyone recommend a cheap good headphone amp that i can plug into my amp. It must be able to send music wireless to the head phones.
I will source the music from same source as with my amp.
Pc music files
It's not clear to me what you have and what you need/want.
Do you have wireless/Bluetooth headphones and want a wireless transmitter? Do you have regular headphones and want to be able to sit further away from your amp?
The former has no need of amplification, so probably isn't technically an amp. The latter, I've never heard of a product that includes a wireless transmitter at the source end (irrespective of whether the source is digital from your computer or analogue from your amp) and a receiver and amplifier at the other end, but then again I've never gone looking. In the case of the latter I'd say get a longer cable or an extension cable. If your computer is your source couldn't you use something like a Chromecast Audio into a combined headphone amp and DAC, and stream directly from your computer, cutting out the middle man of your amp?
Most wireless headphone setups that I know of are configured with a transmitter at the source and the amplification built into the headphones. Not sure whether there is a product to allow you to use existing headphones and effectively uncouple you from the source.
