Not sure how long Dirac live has been out for exactly, but will we see it on Denon, Sony AV receivers etc,?
Does it live up to the hype?..... My room is very open, as you can see! Will Dirac help with this?
Will work? Simple answer no not really
TBH it all boils down how well you've implemented the fundamentals ie speaker setup/placement. EQ can only do so much, placement is still king EQ is a finisher the iceing.
You have a large open plan place with an opening on the left-hand side, in my experience, no room eq will deal with that the bass on that side is gone straight off the bat. Your right speaker is bang in the corner next to glass far from ideal. Your left speaker is basically in free space. I'd argue you would actually get better sound if you bought some smaller speakers and placed them where your picture frames and stone acorn are , perhaps with a sub which I can't currently see if you have one or not.
Basically, id say your speakers are to big for your space. dwonsize pocket the cash and then worry about Eq but as I don't think its going to help you really
No amount of eq is going to balance that up.
Lovely looking room though and love the decor.
Sorry if that's a bit negative but some think EQ is this magic pill and in my experience in the general joe's house it just isn't.
