Will there be a review of Sony 6400ES anytime soon?
TKratz
17
Dear WHF team
I am very interested in the above mentioned Sony receiver. Are you planning to do a review of this receiver anytime soon?
As the successor of the very highly rated 5400ES I guess it should be up high on the list
. It would be highly appreciated.
Thanks for the reply Andy
Sounds like Sony is not always the speediest in providing review samples? Well, I will keep my hopes up
TKratz:
You might say that, I couldn't possibly comment!
Does the 6400 or even the 5400 upscale video that is fed via the HDMI inputs? And if so, is it any good on the 5400?
Hems, your answer is right here & then some (the link below that is).ÿI was struggling to choose between those two earlier in the year, then the Sony had a storming review.ÿYou do know, that the team had to knock the stars off of several AV amps, right? The Yamaha 3900 and the Pioneer 81. I didn't think I could get any more excited about an AV amp, as I want a single setup solution, for movies and music.
http://www.whathifi.com/Review/Sony-STR-DA5400ES/
With what I know about the 6400 it's got a few more extras... the thing which impressed me the most was a fully custom remote that you could program via the HUD of the amps X-bar/menu display. It looked very user friendly and easy to setup. I would only go for the 6400 if you really want to take advantage of the multi-room features. That is what most of the extras focus on. If you want the AV for one room, the 6400 would have a lot of extra features go to waste. The 6400 is a worlds first dual room something or other to support 1080p and 1080i in two rooms... I think, maybe.
I too was wondering about one or the other, then the 5400 won EISA Reciever of 2009 award & they also said;ÿ
"All in all, this is one of the best performing and versatile HD AV receivers available, regardless of price."ÿ
But then...ÿ
...what hi-fi posted a video review of the Arcam AVR600. The day I watched that video review I must have had 108 battles within my mind, 'Doÿnotÿbuy such a huge, heavy, expensive lump of Arcam (Engineered in UK, made in China) steel.'
I lost.
The words "worth every penny" echoed in my mind. I knew everything else in my setup was out of the amps league; all but for the Arcam DV 139 (also reviewed here). They would look nice together, and it wouldn't be so lonely.
ÿ2nd ever post!ÿ
It is true that a lot of features might be wasted if you go for the 6400 model. But I guess that is often the case when you buy high-end equipment? I personally would like to have the networking capability with internet radio and the DNLA function. Don't really need the second room functionality - at this point at least. Might be more relevant when a get a house.
The understanding I was given by Sony's European Technical Marketing Manager is that the 6400 isn't a replacement for the 5400, which continues - instead, limited numbers of the 6400 have been brought in to satisfy a demand from the Custom Install industry, as it has some CI-relevant features the 5400 lacks.
Andrew Everard:The understanding I was given by Sony's European Technical Marketing Manager is that the 6400 isn't a replacement for the 5400, which continues - instead, limited numbers of the 6400 have been brought in to satisfy a demand from the Custom Install industry, as it has some CI-relevant features the 5400 lacks.
So is it a case of get it while its hot ???
Wish they did a silver version dont fancy having to swap all my kit just to match the colour up !!!
Does any one know if it will stream from a NAS device ???/
I have read the 'Network Features' manual from sony but it just mentions a pc running the "ES utility", would have thought if its DLNA
compliant and other DLNA device would be able to communicate without any additional software.
