Dave_
cheeseboy said:daveh75 said:The Pi Zero W is only a tenner, the Pi Zero is only a fiver, but by the time you've bought an Ethernet or WiFi dongle for it you may as well just buy the W.andyjm said:As has been pointed out above, even the lowest spec RasPi will do this without raising a sweat, and can be yours for £27 or there abouts.
There is some excellent open source software available, and I believe a number of high quality piggy back audio boards if you don't want to use a separate DAC.
My original Pi Zero, Pimoroni pHAT DAC, adapters and case cost me just under thirty notes at the ti
Though the Pi Zero and pHAT DAC require soldering of the GPIO headers. So if soldering isn't your thing, then a Zero WH or Pi 3 and DAC from Justboom, HiFiBerry IQaudIO et al will make it plug and play..
hows the sounds with the pHAT Dac? I've been sorely tempted for a while to knock up something so small with the zero 🙂
Fine to my ears.
Though I'd probably go for a HiFiBerry or Justboom DAC Zeros instead and save the soldering of GPIO headers (neither was an option when the original Zero launched)
