I bought a hifi system that I've been using for around 5 months. It consists of the following components:
Arcam SA20 integrated amp
Kef LS50 Meta speakers
REL T5X sub
Bluesound Node streamer
I use the DAC of the BS Node and the amp/speakers are connected with some mid-range silver cable. The size of the room is around 5.5m x 4m and it is relatively dampened.
The sound is overall quite lean, which is particularly noticeable at lower volumes - mids and vocals don't have much weight to them and the bass is lacking. When the volume is turned up the bass is fine, but the vocals are still thin.
Any idea what the culprit(s) might be?
REL T5X sub
