matt49 said:Anderson said:Maybe read a book before you go to bed.
Hmm, yes, maybe Jim Lesurf's Information and Measurement. Required reading for anyone interested in how musical data is stored and retrieved.
Matt
Thanks for that link!
Matt
Vladimir said:The Arcam and the Cyrus feed digital signal to the same DAC, both coaxial, both from the same CD. The issue is either inaccurate rip (normalization is frequently forgoten left ON) or it is mere placebo.
Matt
Chapter 2 is interesting, and limitations of an analogue channel capacity that limits the amount of data a ADC can capture includes the response time of the actual conductor (inherent impedance) lends weitght to the cables must have an influence on the SQ argument. Occurred to me that my speaker cables are too long, so not only are they reducting the control the amp has over the speakers, but they are coiled up as cables inevitably are when tucked away, which must also give rise to some latent impedance that affects the conductivity and phase of the signal passing through them. Whether I can hear it is another matter.
Of course, if you use Nordost cables, the signal travels at 87% of the speed of light, presumably though there is a specific orientation, and a specially designed cable holder / router to ensure that they lay in the right position for optimum transmission that you can also purchase as an extra.
boggit said:I find rather strange that we never had these conversations about CD players a spinny digital thing with a DAC chip and analog output stage. DAC chips are the easy headline a Wolfson xxxxxxxxx wow. I take it as gospel that the chosen chip is going to do its job of DA conversion. The clever bit, the bit that makes the differance to SQ is the analog and PSU sections this is side that is difficult and expensive to implement in a quality device.
Electro said:boggit said:I find rather strange that we never had these conversations about CD players a spinny digital thing with a DAC chip and analog output stage. DAC chips are the easy headline a Wolfson xxxxxxxxx wow. I take it as gospel that the chosen chip is going to do its job of DA conversion. The clever bit, the bit that makes the differance to SQ is the analog and PSU sections this is side that is difficult and expensive to implement in a quality device.
I agree , the biggest difference in sound quality between digital players and dac's is found in the analogue output stage imo .*smile*
MajorFubar said:I only just saw this thread, I figured it was something I had knowledge about and I could offer some positive contibution to help the OP. Then half way down the first page someone suggested in all seriousness that the OP's SQ issues are caused by him using WiFi instead of a direct cabled connection. Then a few posts underneath someone suggested that a streamer will never sound as good as a CD player because it 'reformats the data' unlike a CD player which is 'made for the job' (I might be slightly paraphrasing; they were words to that effect). And it was at that point I realised why I left the forum for a while.
Deep breath. Ah that's better.
Vladimir said:Logical, but still no one seems to hear a difference between a cheap Onkyo CDP player or an expensive audiophile CDP in a blind test. If the expensive one sounds different in a blind test, they voiced it intentionally, which means they ruined its flat FR and it is no longer a High Fidelity component. You cannot change resolution in the analog section, you can just mess up the FR. Like when a photo has a slight discoloration but it still has the same resolution.
The whole purpose of Perfect Sound Forever was to solve sources as a variation in sound quality once and for all. Moving from CD to files just solved the storage issues, didn't improve sound quality at all. Sound quality was solved in the CD era because it breached the border where our hearing can detect differences.
What you buy with a high class audiophile CDP is build quality, durability, the feel of it, how it works like a high precission robot, the remote, even the intentionally slowed down reading operation, building up expectation like playing an LP. It looks, works and sounds great. The badge on top of it is the delicious pride of ownership for such a quality craftsmanship. If it sounds better, its not because of the sound but because of the whole experience. This is why the Electrocompaniet EMC 1 UP has an exposed transport mechanism and a clamp. To stimulate the experience, like when you play records. The brochure blurb about stability is just a pleasant bonus.
I'd never dream of speaking on behalf of someone like Vladimir but I've read his post a few times now and I can't see where he's suggested that at all.kmlav said:Vladimir said:Logical, but still no one seems to hear a difference between a cheap Onkyo CDP player or an expensive audiophile CDP in a blind test. If the expensive one sounds different in a blind test, they voiced it intentionally, which means they ruined its flat FR and it is no longer a High Fidelity component. You cannot change resolution in the analog section, you can just mess up the FR. Like when a photo has a slight discoloration but it still has the same resolution.
I'm sorry but this is not true. This notion that its only a hallowed few that actually have the ears and the insight to realize that HiFi is a myth is nonsense.
Vladimir said:What you buy with a high class audiophile CDP is build quality, durability, the feel of it, how it works like a high precission robot, the remote, even the intentionally slowed down reading operation, building up expectation like playing an LP. It looks, works and sounds great. The badge on top of it is the delicious pride of ownership for such a quality craftsmanship. If it sounds better, its not because of the sound but because of the whole experience.
Infiniteloop said:Vladimir said:Logical, but still no one seems to hear a difference between a cheap Onkyo CDP player or an expensive audiophile CDP in a blind test. If the expensive one sounds different in a blind test, they voiced it intentionally, which means they ruined its flat FR and it is no longer a High Fidelity component. You cannot change resolution in the analog section, you can just mess up the FR. Like when a photo has a slight discoloration but it still has the same resolution.
I'm sorry Vlad, but in my experience, I cannot agree. My Mac Mini, which is kept pretty much out of sight and affords me zero in terms of musical anticipation - foreplay - if you like, sounds massively better (with a DAC and files ripped from CDs) than any CD player I've ever owned.
Infiniteloop said:I'm sorry Vlad, but in my experience, I cannot agree. My Mac Mini, which is kept pretty much out of sight and affords me zero in terms of musical anticipation - foreplay - if you like, sounds massively better (with a DAC and files ripped from CDs) than any CD player I've ever owned.
davedotco said:The issue here is that I have, over the years, tested these effects and know them to be all in the mind (my mind that is), but despite being 100% sure that there is no difference, I still hear what I hear.
kmlav said:I would have to agree with this. I was just looking for a bit of help and advise on the way I was doing things not really to debate the detail of the data and as the Major says I now realise why I had given up with this fourm. That said there has been some good advise from someone with almost the same kit as me who had the same issue so there is some light.
cheeseboy said:davedotco said:The issue here is that I have, over the years, tested these effects and know them to be all in the mind (my mind that is), but despite being 100% sure that there is no difference, I still hear what I hear.
This is the main crux of most of these threads I feel. It tends to end up being those that for whatever reason refuse to accept there is no real word difference because they hear it. Yet, at the same time would happily accept visual illusions as just that - ie an illusion, but one that fools the mind in to interperating something differently. Kind of odd really that somebody can accept visual illusions, but not auditory ones.
