Which speakers for my tasty new amp?
I'm new to the forum, hence have a nice newbie question for you..which speakers should I buy?
I have the Fatman Ipod dock mkII http://www.fat-man.co.uk/docs/product_07/iTube_ValveDock_MkII.shtml
I kindof understand most of the specs but am not quite sure the best way to match that up to a suitable set of speakers. What's best to try to match up..if the amp is 25W output per channel, then what rating speakers are best? What will get me the best sound for an average budget? I am looking to spend around £200 but can be flexible.
Here's the output specs..
Main Features
  • iTube Vacuum Tube Amplifier
  • Separate Dock for Apple iPod or iPhone
  • Valve processing gives warm, rich, audio characteristics
  • Now with USB input
Specifications
  • Source Inputs: 1 x USB input, 1 x pair RCA input
  • Power Output: 25Wx2
  • Frequency Response: 20Hz - 20KHz (±1.5Db)
  • Distortion: ≤0.5%
  • Signal-To-Noise Ratio: ≥86Db
  • Input Sensitivity: 350mV
  • Input Impedance: 100KΩ
  • Output Impedance: 4Ω, 8Ω
  • Tubes Used: 6N1 x 2, 6E2 x 1
  • Power Supply: AC100~120V/50~60Hz
  • Amp Dimensions (WxHxD): 260x145x130mm
  • Dock Dimensions (WxHxD): 155x130x123mm
  • Amp Weight: 4.3KGs
  • Amp Type: Hybrid
    Nice one, Adam
Hi Adam,
What with your amp being so portable it would make sense to go auditioning for a day.
That end of the market is very competitive and lots of dealers have deals on at this time of year.
Matt
matthaskell said:
Hi Adam,
Matt
+1
And I would opt for rather sensitive speakers with that kind op power output. At least 90dB.
The review section on this site show them as will the manufacturers website.
If you go to reviews>Hifi>speakers>select an appropriate speaker and then click specification you should see it
http://www.whathifi.com/review/mission-mx2/specs
The higher the sensitivity the easier it will be for the amp to drive and the Fatman produces 30 wpc, which is fine as long as paired sensibly.
Matt
