hybridauth_Twitter_37661334
Hi, i'm considering a soundbar to replace my av system as I'm fed up with all the associated wires, it needs to have at least 3 hdmi sockets and preferably a sub, it can't be to wide as I only have a av rack, main use is going to be TV viewing in HD and SD, occasional Blu-ray viewing and some music listening, max budget £800
simonlewis
590
Sorry i can't help you with your question, have you checked out the reviews on WHFS&V,
nice avatar btw, just one question what are you going to do in two months time ?
Legacy260
9
You may be limited on the HDMI front as very few have 3 inputs. The JBL SB 400 is worth a look at the lower end of the scale, the Monitor ASB is good but no sub woofer and the Yamaha YSP 2200 is woth a very good listen.
Joe Cox
Content Director, What Hi-Fi?
Staff member
May 31, 2007
275
16
18,895
Yes. You connect your TV's HDMI input to soundbar HDMI output first. If your TV supports HDMI ARC (audio return channel) then it can then get AV from all other devices. Otherwise you need to also connect an optical cable between your soundbar and TV, and then you're done.
