Which sound card under £100 ? External or PCI ?
Dr. Delban
6
I mostly listen to the music from my PC (Youtube, Winamp, Foobar) and it looks like my 8 year old sound card has died? Still not diagnosed.
I am a budget audiophile. I have a pair of MA BX-2 and Opera 1.5 speakers, hooked up to a Yamaha A-S501.
Do external cards make much difference? I don't usually do gaming. Once every few years i go on a few months gaming binge and then I stop gaming completely.
If I get a USB sound card will it still work ok for gaming? As of the special effects etc. (silly question really) ?
Is there a significant difference in sound between a PCI card and external USB?
All my life I've been using Creative Sound Blaster sound cards.
Hi. Just get a Behringer UCA202 audio interface. If you don't need surround, it's ok (imo). But, if I remember correctly, the AS501 has digital inputs as well. So you could just get a USB to SPDIF converter cable, and plug it into the COAX input of the Yamaha. Problem solved 😉
