which is the best option?
Hello,
Soon I will soon be buying an av pre/pro, and wondered if there would be a benefit, from buyin :
a seperate 2channel power amp (NAD c272) + a 5channel (NAD T955) VS a 7 channel amp (NAD T975 or NAD M25).
Would there be a better performance in 2 channel audio, or is it a waste of money?
Thanks in advance,
Kevin Brincat.
I 'think' it would come down to which pre you have and how good that is with music, especially if you're set on nad power amps. (am assuming thats why you've posted it in the Hi-fi section)
You could always buy a 7 channel power and a 2 channel and bi amp the fronts.
fast eddie:I 'think' it would come down to which pre you have and how good that is with music, especially if you're set on nad power amps. (am assuming thats why you've posted it in the Hi-fi section) You could always buy a 7 channel power and a 2 channel and bi amp the fronts.
Thanks for your answer eddie;
I was thinking about the nad m15 onkyo and marantz pre/pro
What do you mean by "especially" when refering to NAD amps?
