- Mar 22, 2009
- 153
- 0
- 0
Bought a new AV amp and got it home Friday, for me first thing to check out was the Stereo, Once that was done turned my attention to AV setup, ran the Audyssey auto EQ, went in and reset the distances, got out the SPL meter and reset the Levels, always run rears about 6dB up, I left the EQ initially and got out a couple of DVD's for a listen but felt it was a little Bass light, I could turn up the Sub but could not change the auto EQ speaker settings, I had to copy the Audyssey settings in to the Preset EQ and up the Front and side speakers below 250Hz.
OK back to the purpose of the post, when I get out DVD's to check my system out (Or to show the system off to friends
) I usually use the same scenes, I start with the Matrix Foyer scene, some great effects with shell casings dropping on the floor all round you, sometimes then I go to the opening scene of Blade II in DTS, I get out Titan AE the Ice field scene in both DD & DTS if I want to check out Bass/Sub levels there are some really good low bass in there.
Do you have favorite scenes you use if you are setting up a system or just showing off.
