System Musical Fidelity A5 Integrated Amp Musical Fidleity Nu-Vista CD3 Linn Sondek LP12 Mission 753 Freedoms I've had my Musical Fidelity amp and cd player about 6 months and need to get some new speaker cable as the stuff I have at present (and have had for longer than i'm too ashamed to say) is a cheap un-named brand of bi-wire given to me as a freebie when I bought my speakers. I need one of 2 metres length and one of 5 metres length and have shortlisted three different makes. Ecosse QED Chord Company Given my system and the particular sonic traits it may have, which of the above cables listed or any not listed would best be suited? I'm also wondering do the benefits of bi-wiring really make it worth the extra expenditure as I could spend the £200 I have at present and go for a more expensive single run of cable version of the bi-wire available cables, or if bi-wiring does make such a significant difference a cheaper bi-wire. Then again do I wait (6 months +) until I've got closer to £400 and get a more expensive bi-wire such as the Ecosse ES4.45 or QED Genesis silver spiral? I know it's a case of you pays yer money and takes yer choice but I can't auditon the cables so advice from those of you with vastly more experience in such matters would be greatly appreciated. Thanks PE.
