Which cables to be used
Li
Dears
can anyone there be so kind to advise me what cables I should use to connect these speakers to the amplifier:
Amplif: Yamaha RX-A2040
Speakers
Monitor Audio set: Silver 8 floorstanding Silver Centre, 2X Silver FX surround Silver W12 subwoofer
thanks a lot in advance
Li
thank you for your reply, but what kind of speaker cables? that was my question, any name, mark, lable. I can afford only about 500 USD.
chebby
1,255
27
19,220
B
BIGBERNARDBRESSLAW
If you want to spend lots of money you can, but you really don't need to as you will not hear any difference.
Some Van Damme Blue Series Studio Grade speaker cable 2 x 4mm would easily be good enough for your needs. http://www.van-damme.com/23.html
http://www.a1-sound.co.uk/product/van-damme-blue-series-studio-grade-speaker-cable-2-x-4mm
