Which cable for connecting an amp with a subwoofer?
Hi, I would like to know which type of cable should I use to connect an integrated amplifier (Marantz PM7003) to a subwoofer B&W ASW608 through pre out (L+R). Should I use normal interconect cable or two subwoofer cables? How much should I spend for the cables? Any suggestions (QED, Chord, etc.)?
Any well-shielded interconnect should be fine, but take care with the routing of the cable, as long runs are more prone to picking up hum.
Thanks Andrew, I think the lenght should not be a problem. I only need about 2 - 3 meters. Will the Qed Performance Audio 1 be ok?
