altruistic.lemon
- Jul 25, 2011
- 64
- 0
- 0
So if I described my Pioneer amp as "transparent, coherent and with impeccable timing", while my DAC has a "truly organic sound" what do I really mean?
			altruistic.lemon said:So if I described my Pioneer amp as "transparent, coherent and with impeccable timing", while my DAC has a "truly organic sound" what do I really mean?
moon said:@ Overdose, no pictures of see through amps?
altruistic.lemon said:In the end, it's the speakers that make the difference, amps just peripheral.
AlmaataKZ said:Here is a pic of an active speaker so tranparent that it is invisible:
MeanandGreen said:This is just a perception of being faster, it isn't actually faster. If you counted the beats from a portion of the same track at a given time period on a loose "slow" amp, and the same on a tight "fast" amp the results would be the same, at exactly the same time.
So if "good timing" means "tight/fast" or it has good definition, I wish they would just say that. I think "timing" is the wrong word to use and it obviously is a cause for confusion.
Covenanter said:"... rolls off its bass a little early ..."
Que?
Chris
BenLaw said:Playing devil's advocate, is there any reason why there can't be an 'audibly transparent' passive crossover?
BenLaw said:Recent venues at which I have been to see amplified music (I guess what you are referring to as a 'rock concert') include Manchester Apollo, Manchester academy and the cockpit in Leeds. Compared to my system, none of these is more transparent than my system, nor do they comparatively sound effing good. Over the years the same goes for a variety of venues and nightclubs in different UK cities and abroad. Where do you go that sounds so great?
SpursGator said:Most people here love music, so here's my advice if you are confused about transparency: Go see some live music. Go to a rock concert, at a venue bigger than a bar but no bigger than the Royal Albert Hall. Go to a jazz club that is established enough to have a big sound system. Go to a symphony. I suspect that basically everyone here has done this, but I also suspect that for some of you, it's been awhile.
Go and do this and listen to the sound:
1. This is what is meant by transparency.
2. Note how effing good it sounds.
3. Accept that your system does not sound this good and cannot and will never
SpursGator said:Yes. When you feed an amplified music signal to an electronic network of soldered-together parts that tears it apart and sends parts of the signal to two different drivers with different moving masses, radiating areas, impedences, shapes, and location on a baffle, you simply are not going to get something coming out which is exactly like what you fed in. Common sense here folks.
I keep running into people on this forum who want to debate whether high-end gear is really just 'all marketing' - the accusation is that, above a certain level, everything sounds the same because it has reached some 'perfect' level of transparency, and how can it sound better than the original?
Hifi is about trying to get the maximum out of:
1. A recording which is never perfect and often highly flawed
2. Source components which are recreating sound where none really exists
3. Amplifiers which ALWAYS change the sound based on decisions made by its designers
4. Speakers which cannot ever perfectly reproduce any sound.
Hifi is the art of creating a fake audible image of something that isn't really there. It will never sound 100% right! 100% right would be 100% transparent - i.e., the stereo kit disappears completely. It's every designers goal but it isn't achieveable.
So it's legitimate to judge kit on transparency, since no one is at 100%, and it's a primary design goal. At a given price level - especially 500 quid - we will be very far indeed from 100% so there is plenty of room for a new model to come in and redefine what is 'good' at that price. I don't see the knock.
visionary said:Yes but...
I accept your argument if the jazz club has NO sound system. If it does then you're comparing their sound system in the mix as well. Might as well say "does my system sound the same as a Marshall amp into a 4x12?" or "Has my lounge got the acoustics of Ronnie Scott's?"
End of the day what matters is do you like the way your system sounds in your setting? If yes, leave it alone. If no, identify what you don't like and look for a specific solution. Arguing semantics, like resistance, is futile.
