SpursGator said:
			Yes. When you feed an amplified music signal to an electronic network of soldered-together parts that tears it apart and sends parts of the signal to two different drivers with different moving masses, radiating areas, impedences, shapes, and location on a baffle, you simply are not going to get something coming out which is exactly like what you fed in. Common sense here folks.
I keep running into people on this forum who want to debate whether high-end gear is really just 'all marketing' - the accusation is that, above a certain level, everything sounds the same because it has reached some 'perfect' level of transparency, and how can it sound better than the original?
Most people here love music, so here's my advice if you are confused about transparency: Go see some live music. Go to a rock concert, at a venue bigger than a bar but no bigger than the Royal Albert Hall. Go to a jazz club that is established enough to have a big sound system. Go to a symphony. I suspect that basically everyone here has done this, but I also suspect that for some of you, it's been awhile.
Go and do this and listen to the sound:
1. This is what is meant by transparency. It's largely still amplifed sound and from speakers that are flawed, re 4. below.
2. Note how effing good it sounds. It's still amplified, (mainly active amplification) and it's just louder, sometimes sounds damned awful, due to distortion by cranking up the volume too much. Room acoustics can also be bad.
3. Accept that your system does not sound this good and cannot and will never. Cannot sound the same you mean.
Hifi is about trying to get the maximum out of:
1. A recording which is never perfect and often highly flawed. A recording can quite easily capture every nuance.
2. Source components which are recreating sound where none really exists. Audibly transparent components do exist, your DAC is one of those.
3. Amplifiers which ALWAYS change the sound based on decisions made by its designers. They can if the designers want them to, otherwise they can be audibly transparent.
4. Speakers which cannot ever perfectly reproduce any sound. True, to my knowledge.
Hifi is the art of creating a fake audible image of something that isn't really there. It will never sound 100% right! 100% right would be 100% transparent - i.e., the stereo kit disappears completely. It's every designers goal but it isn't achieveable.
So it's legitimate to judge kit on transparency, since no one is at 100%, and it's a primary design goal. At a given price level - especially 500 quid - we will be very far indeed from 100% so there is plenty of room for a new model to come in and redefine what is 'good' at that price. I don't see the knock.
Firstly, I've responded to your points in bold, it was easier than 'quotation chops' (I just made that up).
High end gear is hardly all about marketing, but is largely thus. The widely varying comments from different reviewers tells us that the components can sound vastly different from one another, if they were all attempting transparency or neutrality, then they would all sound very similar. High end is all about selling a product at a premium price and being able to justify it to the customer, so there will be a large element of trying to sound different.
I believe that it is entirely possible to acheive an audibly neutral and transparent system right up to the point of the speakers. That these systems are not necessarily common, says more about what manufacturers think will sell than anything else. Neutrality and transparency is exactly what is aimed for and acheived in the proaudio world, because without it, you never have an accurate datum prior to mixing.
Most music listened to on hifi, is recorded in a studio, so there is no real terms of reference to 'an original event', because different parts of the music are recorded and mixed at different times, the artists are not even always present together during these sessions. It is the recording itself which is the original event and the source, that needs to be carried as faithfully as possible through to the other end.
There is a marked difference between a live gig and listening at home, leaving aside the loudness and acoustics for a moment, a large part of the enjoyment of a live performance is derived from being involved in the event itself with other likeminded people, it's not purely about the music, but also the emotions of simply there. Listening at home can actually give you a clearer rendition of the music and in an uninterrupted and familiar environment, but you will not have the same emotional connection. At home you can relax to your music, at a live event, you will be anything but relaxed.
