- May 30, 2012
- 29
- 0
- 0
Yep - I've definitely got the upgrade bug. Just ordered a 2nd hand Chord Chameleon Silver Plus interconnect off ebay (not VEE plugs, but £30 offer accepted so would have been rude not to) to compare against my existing Chord Crimon (with VEE). To be honest I'm very happy with the sound of my system now with the real breakthrough being upgrading the DAC from Arcam RDAC to REGA DAC - I can't resist tinkering though and if there is a bit more soundsstage out there, a bit more zing to instruments then I'm interested - I suppose it comes down to knowing you've tried rnough combo's to know you've got as much as you can out of your kit. Living in a semi detached I would be cautious of adding more bass.
So the plan was to wait for the interconnects to be delivered and see what that does to the sound. I consistently read this interconnect works well with Rumour and Odyssey speaker cable but now I'm tempted to get some Odyssey 2 cable too, spend a few weeks testing for best combos and ebay whatever doesn't make the grade once conclusions are drawn.
Do you think Odyssey 2 is a worthwhile next purchase to throw in the mix? If so how cheap should I be looking per metre(anyone recommend good place to get from?)? Had a quick look online and looks like approx £20 a metre is as cheap as it comes?
:dance:
:dance:
