Welcome to the forum.Need help cant find one anywhere
I have contacted spendor but they said they dont have any replacement drivers 😔 so im just asking if there is a place where i can get themWelcome to the forum.
Have you perhaps contacted Spendor??
Probably best rather than posting on here. Then find out exactly what driver is fitted to this speaker.
This turns out to be a Spendors own 140mm midrange.
Perhaps to acquire one you might have to buy a whole speaker.
Ok then I will try to have a look, thanks for the advice 👍Yes Spendors own design so you are unlikely to get exact replacements from Wilmslow or the like.
It's not unusual to be unable to find drivers for speakers of this age.
It is a pity Spendor could not suggest a driver that would fit.
Theres a pair going on eBay for £450, however I don't think the OP is in the UK, this may be the only way to get exact copies as simply by replacing with an equivalent driver will make them completely different speakers
