What Streamer would you recommend to a novice at varying price point?
It all depends what you want to spend ... could start with a WiiM Mini as a starting point although I'd probably go for a Pro or Pro Plus depending what DAC your Amp has (assumin it has one).
I've recently found the new Bluesound range to be better sound quality than the WiiM's, I started with the Nano and have also bought a 2024 Node, they're better on their own although I do use an external DAC with them.
My neighbour has just returned an Eversolo Gen 2 in favour of the Bluesound Icon which is getting very positive reviews generally.
What were your neighbour's notes between the Eversolo Gen 2 and the Node Icon?
The main draw is its preamp capability - but there seem to be few pure powered/active speakers these days? So maybe with a good power amp then, but which?
Good question.
If I were to sell my Eversolo Z8 DAC in my study, I would pair up the DMP-A6 Master Gen 2 with my nearfield Adams A7V active monitors. Each has a built in D class and an AB class amp, bass and treble built in respectively.
I think that combination would be great but also I think it will work well with other active speakers such as Elac Navis ARF51 active Bookshelf Speakers or Klipsch KD-400.
A power amp would work too, possibly a pair of mono blocks from Fosi , sure there are better options or if your existing integrated amp has a preamp input, that would be a perfect way to save costs, I believe my Atoll IN100 has it.
Ah, yes it has preamp output and By-Pass (preamp input). Good to know
This allows me to use it as a power amplifier.🙂
I haven't seen "notes" but his commens were ... he had a love / hate relationship with the Eversolo, some tracks he felt it was mind blowingly good and was frustrated with others, he was also frustrated with some issues with the software.
I was on holiday for over 2 weeks so lent him my Nano which he felt, whilst on a few tracks the Eversolo may beat it, but only just .... it didn't have the negatives he didn't like about the Eversolo.
I also lent him my Chord Qutest and he found the combination of that with the Nano, the Eversolo didn't get a look in.
He then ordered the Icon, on it's own it gives everything the Eversolo did but without the negatives and prefers the software, he thinks the Nano and Chord Combo still beats the Icon and may add a Qutest in the future.
Reactions: nopiano
I'd like to put up a Silent Angel streamer against the Eversolos. I know the Node X sounded better than the A6, and I'm sure a Munich M1 (or M1T with a suitable DAC) and PSU would perform very favourably - without all the glitz and glamour.
Reactions: manicm
