Kubs said:Hi Cno what combination would make the sound appear lighter and faster i.e. half full with lead shots?
You could expriment with rice, which is cheap.....if you like the effect, then you would probably need some coloured stuff in your see-through stands.
I think LS50s like solid, heavy stands, so kiln-dried sand is cheap...I dried it out further in the oven: http://www.whathifi.com/forum/hi-fi/adventures-eccentric-irish-hi-fi-enthusiast
As you've said, try different levels (1/4; 1/2; 3/4)....but with your stands, they may look odd if not fully filled, which is where the rice comes in.
If you prefer the sound with heavier filling, try fish tank gravel, as it will fill the area better than pebbles.
The filling does two things: 1) Add weight; 2) Helps deaden the stand. Sometimes you want one without the other and sometimes you want both. Sand is good for both.
