The other day i looked at,watched some youtube videos of the Dynaudio DM 2/6 & DM 2/7, other then the size, weight,price,4 vs 6 ohm and a crossover that's not more different then the size of woofer, there isn't much difference. The power handling,sensitivity, frequency respons is the same, some times a speaker reviewed by whathifi like the B&W 686,685,684 sounds a bit different, they get 3,4 and 5 stars starting from the smal one,the dynaudio's both get 5 stars and there seems to be nothing that's different about the sound, as there often could be if you compare 2 speakers from the same brand and series like the B&W 686/685 (started to look at them when i so an add where a store was selling the DM 2/7 with discount, for the same price as the DM 2/6)
Even the DM2/6 i have heard have a boomy bas (lots of bass) so it's not like the DM 2/6 don't have enough bass for most people,which for me is a good thing, beacuse then i wouldn't need a subwoofer if i bought a pair of DM 2/6
I am not at the moment gonna upgrade to the dynaudio's, mabye in 6 month, from my zensor 1 and jamo sub 200 that adds some bass the zensors is missing, unless you have a mic to messaure the frequency response, it could be difficult to adjust a subwoofer, especially in my case where my zensors are playing full frequency (not cut of in the bass, only have a reciver with no electronic crossover for the dalis) and the dalis might not be so powerfull in the mid bass (100-200hz)
What is the difference between the Dynaudio DM2/6 & DM 2/7
