Thompsonuxb said:
				lpv said:
				David@FrankHarvey said:
			Just to clarify - the differences between digital sources are generally smaller than that of analogue sources, but there can still be quite big differences between digital sources. After adding a Chord Qute EX to Audiolab 8200AP I had at the time (about three years ago) and using it instead of the Audiolab's internal DAC, I was gobsmacked at the difference between listening to Napster via Sonos ZP90.
did you equal voltages of both devices and did you level match loudness on both devices or was it pure subjective judge?
Now this is a sh#t question.
I mean why would he do that.....why!!!?
I've commented that in the lawless level world of home audio equipment, where there are no reference levels (reference voltages) which represent an agreed loudness of music, there is plenty of potential for electrical mis-matching of equipment where the output of one equipment is too quiet or too loud for the following equipment, with the potential for audio signal degradation. The DIN standard made a serious effort to normalise and standardise levels between equipment but that seems to have been abandoned with the consequence that equipment (voltage) matching in consumer audio is a free-for-all. It's a wonder it works at all.?
However, in the recording or broadcast studio, levels are very carefully controlled and understood relative to the audio content they carry, and the entire environment with its many electronic equipments (microphones, mixing consoles, tape recorders, hard disc recorders, sound effects units, limiters, compressors, external inputs from OB trucks via satellite, ear-feeds to presenters, clean feeds to off-site contributors, telephone contributor feeds, ISDN line audio in/outs, feeds to the transmission chain via digital distribution, outputs to CD mastering recorders, LP cutting, etc. etc.). Professional sound people work to a common voltage standard throughout their studio and transmission operation. That means that any single item of equipment can be plugged into any other, and be guaranteed not to overload, clip or distort, or be so quiet that there is noticeable hiss.
Take just as an example, the notes in the service manual for one of my Studer tape recorders, attached. It defines a number of voltage levels; before the unit is ready for operation, the user has to calibrate the recorder. It's not a trivial matter. It means that he must place on it an expensive calibration tape made by a specialist company on which a precise and known amount of magnetism represents a music signal (pure tones, actually). Once that tape is replayed, and depending upon which calibration tape and magnetic flux standard the studio is using, the output voltage of the tape machine is set. Once the replay level is set to the international standard, the record side of the same machine can be similarly calibrated such that a defined input voltage generates a certain magnetic flux on the recording tape, which in turn delivers a defined voltage output upon replay. This is the only sure way to ascertain interchangeability of audio between equipment: prior calibration to known, external standards.
The same logic equally applies at home. If you combine CD player A with preamp B driving power amp C, and you do not calibrate the voltages passing between A, B and C relative to the absolute maximum voltage that the loudest audio represents, you cannot possibly expect a truly high fidelity sound: there are two many compounding factors that will get in the way, such as clipping, where the following equipment runs out of headroom. It makes no sense at all to purchase audio electronics unless you can be sure of the audio voltage it outputs relative to the loudest musical information that it is conveying.
... and if we look inside a piece of professional audio equipment, we see the gain structure from the input sockets, through the various circuit functions to the output sockets. This is most conveniently shown on graph paper, where we can see the levels at various points. See the attached signal flow through a Studer pro tape recorder for the record and replay elements.
None of this prudently implemented gain structure exists in home audio. The erroneous assumption is that anything can be plugged into anything. Whilst that may literally be true on a physical level, (phono plugs fit phono sockets) there is no guarantee whatever that the voltage levels are optimal for hifi sound. Most likely, they will be far too high.
Alan Shaw
