- Aug 10, 2019
- 2,556
- 5
- 0
My grados sr80i sound good just a little to bright, is there any cans out there that will be a good upgrade and give me a nice warm sound?
quadpatch said:I know the QC15's get rave reviews everywhere but I would only recommend them if you absolutely must have the active noise cancelling, for sheer audio quality they are outgunned at this price. Dale's L1 recommendation seems like the safest bet, although it's worth noting that it's open (although it does isolate well for an open headphone). The AKG K550 should probably get a mention as well. For a little bit less the Denon AH-D2000 is being discontinued but is still a great headphone and can be picked up at some HMV stores for £200 instead of £300. It's closed but isolation isn't super considering, a bit on the large/heavy side but superbly comfy and certainly is on the warm side.
Oh and it's not warm but I feel I should mention the VModa M-80. It's rather neutral but with really nice bass. It's certainly a great recommend to be everything that the Grado SR80 is not. Its very well controlled on the higher frequencies, smaller, better styling, much better build... in pretty much every aspect VModa kicks A** but especially sound!
jimm said:My grados sr80i sound good just a little to bright, is there any cans out there that will be a good upgrade and give me a nice warm sound?
