Wanted - Blu-ray player with SA-CD capability and 5.1 analogue output
stevee1966
211
8
18,795
It appears that unless i want to spend big bucks i can get a blu-ray player with SA-CD capability or a one with analogue outputs, but not with both.
Any suggestions at the cheapest player out there which will give me both SA-CD and analogue outputs ?
macdiddy
87
Hi stevee1966 :)
The only player that comes to my mind with both SACD playback and a 5.1 analogue output is the Oppo BDP-103, which retails at around £500 or less if you shop around.
I have seen some cheaper players but they either only play SACD's and don't have the 5.1 analogue output or the other way around ( ie have the 5.1 analogue output but don't play SACD ).
Hope this helps.
:bounce:
stevee1966
211
8
18,795
When i said 'big bucks' the Oppo was the first thing that came to mind. There's also a Marantz, Denon and Cambridge Audio which fit both criteria of SA-CD and analogue output, all around the same £500.
I was hoping i could find something a little bit cheaper.
Marantz and Denon do not have 5.1 channel analogue outs. And Cambridge Audio 752BD is £700.
stevee1966
211
8
18,795
Don't these have 5.1 analogue output :-
http://www.whathifi.com/review/marantz-ud7006
http://www.whathifi.com/review/denon-dbp-2012ud
ellisdj
377
Panasonic bdt500 might fit your criteria.at £170
You need to check it plays sa cd but i am pretty sure it has analogue outs
Deleted member 2457
David at Frank Harvey might be able to do you a forum discount on the Oppo 103, he did with me. ;)
They're older models, replaced by Marantz UD7007 & Denon 3313UD. Both don't have 5.1 channel analogue outs. If you can find the older models, go for it!
