Hi, gbhsi1, I've been using a Little Dot 3 for a couple of years, fed by my Naim amps to drive either my SR60's or, mostly, my Alessandros, (enhanced SR80i's), with excellent results. Can highly recommend the LD3, and "valve rolling" can become another journey in itself, as different valves will give different sounds. I'm in my late 60's, and my hearing isn't as sensitive to higher frequencies, so don't find the Grado sound too bright, but I can definitely hear changes in valves. The sound is clear, very detailed, with the "warmth" valves give (other than the heat from the valves). There's a dedicated website (Littledot.net) where you can get advice on which valves to try. Haven't tried it as a preamp, so can't comment on that.
I'm also assuming that you're happy with your Grados?
