lindsayt said:
QuestForThe13thNote said:
I'd absolutely agree with cno evil. And I definetely think these types of percentages are wise ; my cheapest source is about ten percent and most expensive about 15-20 percent. If I spent more I'd doubt it would be worth it, if I spent less I'd hear it.
Would you hear it in a good way or a bad way?
Surely that would depend what sources we're talking about.
Here's one example from post #10 on the purist thread:
knaithrover said:
I have a Marantz CD48 which sounds so so good and never misses a beat - apparently has a fabled Philips DAC only produced in 1994. I prefer it to my rrp 3.5k Roksan cdp. It cost me 40 English pounds...
I think that allocating 0.1% of the total system budget to the digital source is quite acceptable and sensible - depending on the system.
Id hear not much benefit for my buck, and depending on the price probably not much at all.
this is my point though since if you match a £3295 roksan amp and £3500 CD player with £1000 acoustic energy ae 305 speakers, you very likely won't get the benefit out of the roksan CD player assuming the roksan CD player is very decent at its price in the right system, which I bet it is. This seems to be the experience of that poster, that the cheaper marantz works as well . Its about matching. This is common sense to me but also my experiences to
n the amp side of things, it seems perfectly matched to me if the amp eeks out all the performance of speakers, but pound matched for pound, amps will do that much better, CD players won't.
Btw I'm not criticising that posters choices, but just making the point. If you had a pair of really good performing ae speakers at say £5k , which will perform better on detail and everything at their price point if a good model speaker, could the poster say the same thing with the marantz comparing it to the roksan, assuming as I say both CD players perform best at their price points. I doubt it, as the marantz would probably be shown up against the £5k ae speakers revealing the marantz flaws. This idea people say that a good £30 CD player copes as well as a good £1000 cd one within its design, is wishful thinking. It's impossible at its price, and design. It doesn't mean price reflects performance because law of dim returns comes in. But it's what works better in a matched sense.
I tried a £30 chromecast audio in place of my streamer at £1300, and it's quite obvious it sounded horrendous comparatively and you wouldn't match the two. I've also tried my 1992 Sony CD player (about £100 then) on my system using its dacs and analogue out, and to say it took dynamics out, an understatement. I'm sure I'd get similar results if I tried a £200 ish CD player from today, with basic dac but probably not as bad as dacs much better nowadays.
