There have been a few people who have had their accounts deleted recently, all voluntarily. Maybe there is something going on. I don't think it is Covid.
Regards,
Shadders.
Strange comment
Regards,
Shadders.
Not really, I think he was having a poke at the current level of moderation. If he wasn't I will apologise.Strange comment
However, I certainly hope DougK didn't leave because of my comments. From his last post it doesn't sound like it.
Have to say all my cables probably don't make the most of my system -- and nearly all are ancient.Perhaps you should re-read my post #45. Most (all) comments after had little (nothing) to do with my thread . - It will only go one way from hereon and we don't want to loose all 6 members on this forum 🙂
Threads, once they over 30-40 replies, tend to bring in other aspects, so go totally off-topic.This thread just goes on and on. It was mentioned previously would a manufacturer give inferior cables that didn't make their equipment sound its best. Well if cables dont make a difference why do turntable manufacturers make turntables where you can use the cable of your choice . My project turntable has the sockets for cables but I cant remember that they supplied any. Just a thought
penny pinching at its finest?? 🙂This thread just goes on and on. It was mentioned previously would a manufacturer give inferior cables that didn't make their equipment sound its best. Well if cables dont make a difference why do turntable manufacturers make turntables where you can use the cable of your choice . My project turntable has the sockets for cables but I cant remember that they supplied any. Just a thought
Lets not go there shall we notpenny pinching at its finest?? 🙂
surely they included something otherwise that turntable( would not sound very good.)
you brought it up... 🙂Lets not go there shall we not
I was, and then I wasn't!Unless you are unhappy with aspects of the sound ... none 😎
It was really a rhetorical question. I'm sure my cables can be bettered but my kit sounds fine 'as is'.Unless you are unhappy with aspects of the sound ... none 😎
None. Buy Brasso 🙂Soooooo.....
My cables are as follows: I/C from CD to amp is Merlin Chopin (purchased in 2008); a couple of Chord Crimsons; ancient set of Chord Chrysalis (purchased somewhere around the Stoneage) and speaker cables Atlas Equator.
Which ones would you update to make my system shine?
That's funny. I do actually dismantle all my cables and clean the ends, sockets and posts with white spirit every year. Makes quite a difference.None. Buy Brasso 🙂
There's always one that trips us upThat's what I normally think. I'm not usually a cable swapper. Then comes a cable along ...
Is that purely because of its age?That's funny. I do actually dismantle all my cables and clean the ends, sockets and posts with white spirit every year. Makes quite a difference.
The only I might change is the Chrysalis. Think I've had it since around 2000
Absolutely - like mixing and matching tyres based on what's cheapest.my interconnects have to be by same manufacturer....no real reason I suppose
You like mixing and matching tyres? What hi-fi do you own? 🙂Absolutely - like mixing and matching tyres based on what's cheapest.
