peterpan said:There is Van Damme lc-ofc 4 mm and Van Damme Blue. Which one is the best? And i always terminated the speakercables without plugs on amp and speakers. Good?
[/b]
[/b]
DIB said:peterpan said:There is Van Damme lc-ofc 4 mm and Van Damme Blue. Which one is the best? And i always terminated the speakercables without plugs on amp and speakers. Good?
[/b]
I use the Blue Series Studio Grade UPOFC 4mm cable, plugs at amp end (for ease of use) and unterminated speaker end.
Excellent value cable, I couldn't perceive any difference with the Chord Odyssey it replaced. Plus the blue matches my carpet perfectly![]()
Crocodile said:Over that distance there will be no difference but you may struggle to accommodate the thickness of the 6mm in the binding posts.
Inter_Voice said:Crocodile said:Over that distance there will be no difference but you may struggle to accommodate the thickness of the 6mm in the binding posts.
+1 🙂
Unless you have to use very long cables 4mm is sufficient.
peterpan said:And i always terminated the speakercables without plugs on amp and speakers. Good?
[/b]
