lindsayt said:Vladimir, Vladimir, Vladimir. Are you being serious or are you joking?
Vladimir said:Push pull annihilates any SET for performance and sound quality. A high efficiency speaker + valve amp system is for those that don't care for accuracy and performance, that just want something sounding and looking different, special, unique. And only with female jazz vocals and plucking guitars, mind you. Forget fullrange sound at high SPL and dynamic transients with classical or electronic music altogether.
CnoEvil said:lindsayt said:Vladimir, Vladimir, Vladimir. Are you being serious or are you joking?
He's fishing to see who will bite.
It's Sunday evening and there's no good arguments......yet!
Ok lets break it down:steve_1979 said:This is all true.
But some people like the way they sound. Nothing wrong with that if they enjoy it.
Your question is best answered by letting a decent SET, high efficiency speaker combination speak for itself. Go listen to some.Vladimir said:Let's say I know absolutely nothing about audio. Can someone please explain to me the need for a valve amp today in 2014 without using the following words: quality, better, silkier, smoother, richer, punchier, leaner, musical, sweeter, nicer, brighter, darker, PRaT. Please replace those with: higher, lower, more, less, so I can understand as a layman. Thanks.
lindsayt said:Your question is best answered by letting a decent SET, high efficiency speaker combination speak for itself. Go listen to some.Vladimir said:Let's say I know absolutely nothing about audio. Can someone please explain to me the need for a valve amp today in 2014 without using the following words: quality, better, silkier, smoother, richer, punchier, leaner, musical, sweeter, nicer, brighter, darker, PRaT. Please replace those with: higher, lower, more, less, so I can understand as a layman. Thanks.
CnoEvil said:Go listen and then tell us. Some things just have to be experienced.
plastic penguin said:Welcome back to Snobbyville, PP.
Can we bang a different drum, rather than how great valve/Class A amps are, and what a pile of s###e all others are. *diablo*
CnoEvil said:plastic penguin said:Welcome back to Snobbyville, PP.
Can we bang a different drum, rather than how great valve/Class A amps are, and what a pile of s###e all others are. *diablo*![]()
Whose thread is this anyway? *biggrin*
Hi-FiOutlaw said:Congrats! The boys from the actives will not be happy with this move...*secret*
do you have a pic...?*blush*
lindsayt said:Ok lets break it down:steve_1979 said:This is all true.
I've been to 4 bake-offs where SET's have been compared to push pulls. The SET's have won every time.
Depends what you mean by accuracy and performance. Performance is a subjective term in this context. Accuracy. Depends what you mean by that. If we're talking about tonal accuracy between 20hz and 20khz, you can find high efficiency speakers and SET's that excel in this area. You can also find some that don't. The high eff speakers that excel at tonal accuracy tend to be the huge ones that give you bass extension and bass efficiency. Hoffman's Iron Law.
Special when it comes to dynamics, detail, clarity, physical impact, ability to sound great at low and high volumes, yes agreed. They also do have different front to back soundstaging to conventional low efficiency speakers, which listeners used to the more restrained soundstaging of conventional cones and domes may not like.
SET's and the right high eff speakers are a lot more than two trick ponies. Go and listen to some and compare them against your favourite sub 90 db efficient speakers with solid state or push pull amps. On the subject of vocals, male and female. These are the most important part of the performance for me on the vast majority of rock and pop music. Solid state and push pull just don't quite do it when it comes to putting the vocalist there in your room time after time, recording after recording.
Full range? Is 20hz minus one or two dbs full range enough for you? High SPL? Is 112 dbs per channel at 1 metre (remember this is full range down to 20hz) continuous from my 8 watt SET enough for you? Efficiency beats watts if you've got high enough efficiency.
Some people like the way they sound, because when it comes to putting the vocalist in the room, nothing sounds more realistic than a good SET. Some people like the way high efficiency speakers with SET's sound, because when it comes to the combination of dynamics and clarity, nothing beats them. Some people like the way their restrained / polite sounding conventional cones and domes and solid state amps sound. Nothing wrong with that if they enjoy it.
Vladimir said:Thank you so much both Lindsay and Tannoyed for the write-up.
So if I have large enough and efficient enough speakers, I won't have distortion and clipping from an 8W SET amp? Let's see how big is big enough.
I've used the Crown SPL calculator and for 95dB SPL at listening position 3m away, I will need a 28Wpc amplifier, with reserved headroom of 15dB, to push signal through 105dB efficient speakers.
For an 8Wpc amplifier, I need 110.5 dB efficient speakers so there wont be any clipping and distortion. Any suggestions of new 110dB efficient speakers with 30Hz-30kHz +-3dB FR for a reasonable price that will also fit in my average living room?
