Using Sky+ remote to control Samsung HT-Z320 home cinema system
I have a rev 8 sky+ remote and have configured it for use with my Samsung tv already using 0060 code. The tv speakers are disabled and all sound is operated through the Samsung HT z320 amp. I want to be able to control the volume of the amp using the sky remote and not just the Samsung remote because its a pain using 2 remotes the whole time.
Im aware that the tv button should be pressed then select and 0 together then a Samsung DVD code inputted. Only problem is I can't find a code that works.
Any ideas?
Pindi
68
I never knew my Sky remote could control my amp!
Thanks!!
I appreciate your response but you only do the select and 1 after you have done the select and 0. The select and 0 programs the remote to the amp and allows you to control the volume, stand by and mute operations by using the navigation arrow keys (after pressing the tv button). Select and 1 changes the function of the remote so that the actual remote volume buttons change the volume whether you press the tv button or not.
Also the code list you posted doesn't actually list Samsung, just like every other list on the web. unless samsung is listed under another manufacturer im starting to think they dont have a code for the remote.
The_Lhc
1,176
lonemascot:I appreciate your response but you only do the select and 1 after you have done the select and 0. The select and 0 programs the remote to the amp and allows you to control the volume, stand by and mute operations by using the navigation arrow keys (after pressing the tv button). Select and 1 changes the function of the remote so that the actual remote volume buttons change the volume whether you press the tv button or not.
Yes I know, I've done it myself, my TV doesn't have speakers, so I had no requirement to control a TV.
I did notice that as well but there isn't a great deal I can do about that.
