USB to S/PDIF
jcarruthers
26
Hi all,
Are there any decent cheap USB to S/PDIF convertors that can cope with 24 bit 96 kHz.
My MacBook Air doesn't have an optical output and my Pro has been locked down by work so I can't use Audirvana etc
James
Musical Fidelity do a vlink2 that does exactly what you want. You should be able to pick up a 2nd hand one for about £60. They also do on that handles 24 192 - but that is a lot more expensive
jcarruthers said:
Hi all,
James
My M2Tech Hiface 2 is good. About 100 quid I think
I use an M-Audio USB Transit. Just 100 USD when it was new. It's discontinued but you might be able to find used ones for really cheap prices.
ngibbs said:
jcarruthers said:
Hi all,
James
http://www.whathifi.com/forum/computer-based-media/how-tog-get-the-best-sound-from-a-pc
The Musical Fidelity sounds good - in fact my old V-DAC is on eBay finishing today.
Amazon have them for £100 so it looks like it'll pay for it.
Musical Fidelity V-Link II for the price. Though, Stello U3 is the best!
