abacus said:All except USB3 has limited current capabilities which are normally exceeded with the better quality DACs etc, hence the reason for a separate power supply. (If you look at quite a few portable HDD you will find they have 2 USB A plugs into 1 USB B plug thus doubling the current available.
A good DAC will also use asynchronous USB, meaning the DAC has full control over the signal.
The argument as to which type of power supply is best for audio has been going on for years, however in reality if a power supply is designed correctly for the job in hand, it should not affect the sound. (As always cost will enter into it)
Bill
Green Bow said:I have no idea if cheap USB cables affect signals. I know we use asynchronous USB devices for more accurate timing. Timing which is mean to be mucked up by cheap cables, and cheap clocks. If this is true, it makes sense that cheaply transmitted digital signals will be poorer.
Having said that, I have not heard it yet.
Green Bow said:I have a four way USB hub. It has a 2A charger for the four sockets, at 0.5A each. I had not thought about another power adapter for it.
However all is not well.
There is a strange problem when attaching the Meridian Explorer (ME) to the hub. Simply, there is no power to the ME. The ME lights flash for a second but that is it. No music. No light to signify music sampling rate. The light on the USB hub shows as if there is nothing attached. (Ports with a USB device attached, flash.)
Secondly, the principle of the audio-quality USB cable is lost when using a USB hub. It means a cheap USB cable to the hub, and then audio quality out of the USB. You have cheap cable in the circuit. On top of that, I think quality is lost over connections (which the hub is,) anyway.
I think you can get hubs that can be attached to USB ports on pc. I think I saw one recently and it had just one USB out. It was powered externally. I think that could be the solution, but then the ME might not run on it. As it doesn't run on mine.
I think the only way would be hacking the audio-quality USB cable. Or feeding the ME independently. I haven't thought yet how to do either though.
I guess I am stuck, but no worries.
However I think I have read that, independent power on a cheap USB cable is better than only audio-USB cable.
Green Bow said:However do odd blips in data cause huge drop outs.
