Upgrading from a Toshiba 32WLT66 - your thoughts welcomed
Juzzie Wuzzie
430
240
19,270
Current television is the above (c.1300v760), and viewing distance is c.2metres.
Mainly watch Sky Sports (HD) Bluerays and DVD. Very little standard definition viewing.
Questions are (which intermingle):
1. would it be worth getting a full HD television?
2. what size? 32" / 37-40".
I like the current size of my television as it is not obtrusive in my "small" lounge of c.3metres square. That said, would I notice the change to full HD? If not at 32", what about at the larger sizes - or do they get too large for the viewing distance.
Thoughts?
Well, I'd say you could certainly have a 37 - 40" TV at that distance, but 32" would also be fine - up to you really which you prefer. You can always do the old cut out a piece of card trick which is roughly the size of a 37 - 40" set you're considering and see how big it looks.
As for HD Ready vs Full HD, I would leave that to your viewing preferences - will it be mostly SD, or more HD? If more HD, I'd be tempted to look at Full HD. Many people say you can't see the difference below 42" but I certainly could from about 6-7 feet when I was looking at a demo of a couple 32" sets a few weeks back (same set and same viewing material except one was being fed 720p version and the other 1080p). Again, might be best to seek out a demo and see what you think.
EDIT - sorry, see you put your viewing preferences in the first post! In which case, I'd definitely look at some Full HD sets.
seeing as you mostly watch hd , 37 to 42 inches would be fine , id check out the sony 37,or 40w5500 and samsung 37, or 40b650 , both very good full hd sets with 100hz , which would handle the fast pace of sports well , or the samsung ue40b7020 , an led backlight lcd which also has 100hz and a very good hd picture , some people on here have said its nearly as good as the pioneer kuro plasma , which is generally said to be the best tv out there , very reasonably priced too in my opinion ...
