Soopafly49 said:
Dont know why my post ended up in the middle of my previous post but do you think having them surrounds backs celing mounted with surrounds on stands will be ok. This is to avoid having speakers in the middle of the floor with wires trailing of.
If you can wall mount, that would be your better option. Both your surround speakers and your rear speakers should ideally be around 2ft-3ft above seated ear height in a 7.1 set-up if you follow conventional advice.
Ceiling mounting will still work well, just not optimally. In that case, fire the speakers downwards so that the tweaters fire around 2-3ft over the heads of the listeners. The same goes for the L/R surrounds, get them off the stands if you can, and up on the walls otherwise the surround effects will be too localised to create a sufficiently diffuse rear sound field.
