- Aug 10, 2019
- 2,556
- 5
- 0
System Details:
Record Deck - Linn LP12 Sondeck (1985 – no mods) with fairly recent upgrade to Ittock arm & Adikt cartridge.
CD Player - Arcam CD92
Amplifier - Arcam A75+
Speakers - Linn Katan (no room for floor standers but these are mounted on very heavy home made stands to reduce any shelf vibration)
Also – Nakamichi B2 cassette deck (virtually redundant) & Aiwa analogue tuner (old)
Music:
Allsorts but mainly Classical & Rock/Pop on both CD & Vinyl.
Problem:
The system sounds pretty good but just lacks a bit of bass ‘oomph’ if you know what I mean!!!
I am going to install a subwoofer probably an MJ Acoustics Ref 100. I’m also considering upgrading the amplifier as I think this could be a weak spot in the system but I’m not sure whether to stick with Arcam or try the Roksan KandyMk L.III or save up some more and move to a Pre/Power set up. I also want a fairly cheap DAB radio to replace the aging Aiwa (Cambridge Audio DAB500 or Denon TU-1500AE).
I would welcome any comments or recommendations.
Jolly Bodger
Music:
Problem:
Jolly Bodger
