- Aug 10, 2019
- 2,556
- 5
- 0
Hi everyone,
i need some advice here.. i have Monitor Audio BR2, Rotel RA-04 Amp, Cyrus CD6s CDP, with Audioquest Diamond Back Interconnect, I currently Biwire my speaker with Audioquest Type 4 for the high and Wireworld Stream for low signal. I feel the sound is not optimal in the low area. The high and mid is quite good (for my taste).
What kind of upgrade can i do without do some major change in my current system?
Maybe I sould try bi amping? what kind of amp should do you recomend?
Or maybe you have another solution..
