Hi all,
I am having a BBQ on the w/end so I am taking a long lunch break to make sure my speakers and amp (yama s500/tannoys) are firing (and maybe catch some cricket
So I pick a track that I know well and something odd has happened.
If anyone knows the track "galvanize" by the Chemical brothers, they will know that about a minute in, there is a low bass phrase "push the button".
Well, on my new upgraded amp this phrase has almost disappeared. Its rendered as "Pu...th...bu..."
Can someone either explain what might have happened, whether this might indicate a fault (the amp was a return and the salesman said "erm, ah , he changed his mind".
The same thing happens through headphones so its not the speakers.
Alternatively, if you dont know this track, what tracks do you use to test the base etc on your hifi?
