TV Wall Brackets
stevenjonas
27
I am about to buy 2 new TVs: a Samsung UE46F8000 & a Samsung UE22F400 or 4010 one for the living room & one for the kitchen.
I want them both to be on wall brackets, so that they can be swiveled a bit.
I need them both to be as flush to their respective walls as possible.
I would appreciate advice on which wall brackets sit the flushest to the wall for each of these sizes.
>any thanks.
pauln
137
Have a look at Vogel or Premiere Mounts. Both do brackets that will fold up to about 4" or 5" from the wall (which is as close as you can go really without having cable issues) but will also cantilever out to allow you to swivel the screen to at least 45 and up to 90 degrees depending on screen size. Both are expensive but you get what you pay for - very strong, well made products and reasonably easy to install. I speak from experience; I have products from both companies as I have two TV's and two computer monitors wall mounted.
