posted earlier today i am looking for someone who has this tv and can maybe help me at the moment i have used the pixar bluray disc UP to try to calibrate my tv and have ended up with the contrast on full at 100
my brightness is set at 55
colour is set at 55
sharpness set at 3
the active control is set to the off position as is the contrast+ when using the disc you have to make the bars dissapear by adjusting brightness then contrast and then it asks for GAMMA although on this set i have no setting for this
after adjusting the brightness i set the contrast but the only way i can make the bars dissapear is by setting the contrast all the way up if you have used a disney bluray to calibrate you know what bars i mean
colour is set at 55
sharpness set at 3
