Nope - a lot of the discs are set for 50Hz - the uk mains frequency.
All you will need is a standard tungsten (60w or 100w pearl bulb - the ones being phased out!) lamp, and the dots/lines on the strobe disc will appear to freeze if the speed is correct.
Best to do this at night obv, as daylight will drown out the 50Hz light from the lamp.
If they are moving forward/backward, then the speed is either fast/slow.
