Trying to identify a speaker wall plate
Tamurlaine
Hello,
I am trying to identify what type of wall plate I am looking at.
There are three - two with a single socket, positioned where one might want a left and right wall-mounted speaker (either side of a mantelpiece). And the third is identical but has two sockets, and is central, low down (so where one might put a Hifi system). I am 99 percent sure they are connected for speakers as the previous occupants did have wall mounted speakers.
The sockets are ~3-4mm internal diameter. Both a banana plug and a mono 3.5mm jack plug fit. The outer ring is hexagonal externally. I am leaning towards them being 3.5mm mono jack, since a banana plug would need two sockets per speaker, and there's only one. Unless the hexagonal outer is for fixing the negative wire?
I will post a photo as soon as I can work out how. Any thoughts appreciated.
andyjm
15
Tamurlaine said:
Hello,
Sounds like a mono jack, though the usual choice would have been 1/4 inch not 3.5mm. A picture would help, ideally of the innards of the plate if you can remove it from the wall.
Al ears
Moderator
andyjm said:
Tamurlaine said:
Hello,
Could be a mono jack. Is there any way you could contact the previous occupants?
Benedict_Arnold
661
Unscrew the wall plates and see what's behind them.
Then get a simple circuit tester from B&Q (kind of like we used to jerry-rig with a battery, some crocodile clips and a torch or torch light bulb) to determine the connections.
ASK THE COMMUNITY
