Tonsil Maestro II 180 or others ?Need advice on front ported floorstanders
OviPsk
Anyone heard these ? - Tonsil Maestro II 180
Any opinions ?
No , i cant audition :( sadly.
Need advice on front ported floorstanders(for very close to wall positioning)
Thx in advance :)
Any opinions ?
Thx in advance :)
Nope. Also just be aware that just because speakers are front ported it doesn't necessarily mean they are suitable for close to wall positioning.
Vladimir
220
7
You should check Polish audio forums about Tonsil. If you don't know polish try your best using google translate.
IMO these should be on par with the cheapest floorstanders on offer from Magnat and Jamo. If you can't audition them, best to look for something else.
OviPsk
Ok so what are my options ..i can go for either a soundbar+sub or floorstanders+amp?Floorstanders would be great becouse i could use dual zone speaker outputs many amps offer another thing speakers would have to be placed between furniture. And i doubt i can leave more than 6in betwen speakes and back wall..so what is my best bet at @800 pounds.
OviPsk
Thx for the tip but those are not available in my country (not sure theyr available in the EU ) what about AE 103 would those work?
Vladimir
220
7
It's up to you to decide if you like how they sound. I've never heard them but if I had to pick the AE or Tonsil in a blind buy, I'd go for the 103.
lpv
47
at the moment on ebay rega rs3 and chances are it will end as it is now ( £329) .. originally retailing around £700.. work well close to walls too.
