- Aug 10, 2019
- 2,556
- 5
- 0
Hi advice/comments on teh following would be appreciated:
I have an INFOCUS IN78, projected on to a 100" screen. Currently using a Sony DAV S550 as the source.
I am in teh process of upgrading the sound portion by using a LINN AV5103 to integrate with my LINN Aktiv system.
I also am trying to decide which way to go with the source, either an upscaling DVD player or should I go for a Blue Ray player, even though the IN78 is not Full HD.
One other thing to consider is that the AV5103 does not have HDMI connections, so I will need the Blue Ray player to output audio either via analogue or digital audio cable.
Scott
Scott
