jaxwired said:delhk said:Hi Jaxwired, Thanks for putting me onto the NAD C390DD, i found it from reading through some of the threads you wrote, any thoughts on the right speakers? I know you are a big fan of the LS50 but i'm concerned both are very precise with a lot of detail, and the Nad is a bit distant in presentation which might leave me a bit cold. I was thinking C390dd with the MA PL100 which you also liked as the PL100 have a very forward presentation which may balance the C390?
I'd say you're on the right track. Synergy is key to great sound. Hifi equipment all sounds different so it makes sense that certain pairings of amps and speakers work better together. The C390DD does sound smoother and could be called "distant", but IMO that "smoothness" is really just a result of the total lack of noise and distortion. But yes, I think the C390 would pair better with a speaker that leans forward rather than backward.
I would bet the PL100 would be incredible with the C390 because that speaker can be edgy with a bright amp. The smooth C390 would tame them, plus, they could use the massive bass kick the C390 can produce.
I also think the new PMC Twenty line would work well. I have not heard the twenty's but everyone reports that they are brighter than the old i series. This is also true of the fact 3.
Good luck.
I agree the NAD / MA combo theoretically should go really well together, but to be honest I didnt love either item individually and there isnt anywhere to test the two together.....So i have B&W 805 Diamonds on order, now I just need to find an Amp to go with it.....any suggestions?
