Oy, would you seriously consider parting from your Apex sub gosahl? I'm betting you won't 😉
Sure, while AW-12 is a formidable performer is may not be the king of subwoofers. You might get more 'slam' and depth with a bigger model, absolutely. But will it make bass fully integrate with your room and blend seamlessly with your Apex satellites? With two capable subwoofers such as the AW-12 you may get the kind of added flexibility that a single unit just can't provide. Depends on what you want to achieve with this upgrade I suppose. Seamless integration and bass that 'grabs' hold of the room on a larger scale and with far less localization? Chances are greater you'll achive that with two carefully placed and individually calibrated subs through Audyssey Sub EQ HT than with one single unit. Like I said before though, it's often room dependant so you'd have to try it out.
