apogee said:iceman16 said:Is there any chance you can listen to some Focal electra's or the new Sopra range?
Yes, that is the plan.
As you can see from my sig. I use Focal 1028be with AMS 35i. They work great together IME.
CnoEvil said:I recognise and agree with a lot of your description, but
- I don't think that the M6si is of sufficient quality for the Refs, which will only show up its weakness. The M6500 is much more powerful and cleaner sounding
- I find Chord amps sound too forward and analytical for my ears and IMO would be too much with the more forward sounding older Refs..and also for the very Neutral ATCs.
I can't comment on the B&Ws, as I'm not familiar enough with them.
- I think the Audiolab was out of its depth with this quality of speakers....I'm not surprised the ATCs sounded the way they did.
- IMO. In order to hear what these speakers can do, (if you can't hear them through your own amp), you should be using something from Devialet, Classe or Bryston. You also need a Source more in line with the cost of the speakers.
So to sum up my thoughts....I personally wouldn't judge any of these speakers based on the system they were in. I think the B&Ws came out on top, as they were comforting and familiar, especially with the Audiolab source.
- I don't think that the M6si is of sufficient quality for the Refs, which will only show up its weakness. The M6500 is much more powerful and cleaner sounding - I find Chord amps sound too forward and analytical for my ears and IMO would be too much with the more forward sounding older Refs..and also for the very Neutral ATCs. I can't comment on the B&Ws, as I'm not familiar enough with them. - I think the Audiolab was out of its depth with this quality of speakers....I'm not surprised the ATCs sounded the way they did. - IMO. In order to hear what these speakers can do, (if you can't hear them through your own amp), you should be using something from Devialet, Classe or Bryston. You also need a Source more in line with the cost of the speakers.
CnoEvil said:I'm a big fan of the Arcam A49 and Linn DS.
It is worth remembering that all these Reference speakers are the audio equivalent of a Ferrari....put in 2* petrol and the performance will suffer.
Yes, but the OP has been demoing the speakers at F.Harvey and I believe this is an amp that they sell. If he ends up going back for another dem and doesn't lug his own amp there, it would make a good alternative.Andrewjvt said:CnoEvil said:I'm a big fan of the Arcam A49 and Linn DS.
Is not the mf amp 500w per channel though?
