I've recently aquired a Technics SU-V500 amplifier, the amplifier is currently powering a pair of 4 Ohm subwoofers all on channel "A" on both "L & R" therefore total loading of 8 ohms wired in paralel.
My question is on the rear of the amplifier it states: - "A or B 4-16 Ohms" and "A & B 8-16 Ohms" does that mean if I wire to A & B I require 8-16 Ohms per channel or total loading to the amplifier?
A secondary question is if the subwoofers can be powered on independant channels (therefore reciving more power) should they both be on the same L/R side?
This would be to prevent issues with the frequencices being out of phase (they share the same enclosure)
Thanks in advance!
Thanks in advance!
